Possible stupid question
P4SHOCAT
Glenside Pa.
Does anybody know how long it takes for the miles to empty to reset after replacing the battery? It's been two months and still giving me a reading of over 500 miles to empty when I fill up. Just wondering thanks.
RogueClimber
Captain Rob
Marina del Rey CA
Don't most 'modern' vehicles maintain their data when the battery is removed?
Did you have to reset your saved radio stations?
I disconnected the battery while on an extended trip and everything came back just as before
P4SHOCAT
P4SHOCAT
Glenside Pa.
Everything reset back to normal except the miles to empty. The manual says miles to empty will reset to 16 MPG. Then will relearn to the avg. MPG you are really getting. The reset button on the steering wheel just resets the MPG. I can not figure out how to reset the miles to empty. It's not a big deal the gas gauge works fine. Thanks.
WNCHSTR96
Athens, Alabama
That miles to E will not reset, but will adjust if you leave it running at least five minutes or so. I also believe back in the day someone mentioned you can calibrate it with Forscan, maybe I should try and see if I can find that thread?
P4SHOCAT
P4SHOCAT
Glenside Pa.
I already have used up a tank of gas and it still has not reset. There is no way I'm getting 15 or 16 MPG towing my boat to the lake. I will run the gas down to around a quarter tank and fill up to see if that does anything. The manual says it is supposed to reset, but doesn't say how long it takes.
WNCHSTR96
Athens, Alabama
Well that’s strange, don’t know what to tell you. I did look for that calibration thing I saw but it turns out it was for 2015 to 2020 F150’s.
P4SHOCAT
P4SHOCAT
Glenside Pa.
I will be filling her up tomorrow. Took the boat to the lake today and the miles to empty looked a little more realistic. Will find out tomorrow morning when I fill it up. If it goes to high 300's maybe 400 to empty then alls good. Will update tomorrow.
WNCHSTR96
Athens, Alabama
Was realizing that I use the Fuelly app (a recommendation from a FRF member) and noticed my mpg screen is usually 0.2 to 0.5 gallons off from my actual according to the app. Not sure how your hand calculations are panning out.
