mtnghost
Liked that the icons were adjustable out the box where the deavers I would have to repurchase if my needs changed or I picked the wrong one. LCA will likely get new ball joints and bushings, whatever it needs. I was thinking geysers in the front if I have to, because I would like the balance of progressive front and rear springs. Factory is progressive from what I gather and I’m ok sticking with them if they are not in dire need of replacement. So far I don’t think I “need” shocks. I have been looking at a pair in the garage sale section that I think I really want but would like to figure out my set up before spending a bunch testing to see what works. Thank you for the heads up on rebuild costs of the factory 2.5 shocks. If I did shocks I really like the idea of the live valve with the controller but it seems like more work and money than it’s worth. Also being able to change my suspension for the different uses is a very tempting feature. For now I just want to get the things that don’t work working. Thanks again for the tips!Just for a simple overland rig I would rebuild the stock LCA. Deaver or icon not sure on that one I have Deaver +2 @mwaite09 has Icon setup in stock hight configuration. not sure witch I like better We both are running Eibach in the front On low. Both trucks are very capable of overlanding.
I have been rebuilding the fox 2.5 my self they are not that difficult to do. and the parts and oil cost around 25-28 bucks a shock. Once you get shader valves in all the ones you own.
