FRONT SHAFT LOCKED IN 2wd
florida
I have a 2012 ford raptor and the front 4 wheel drive shaft coming from the transfer case is always locked. Even in 2wd … I changed out the transfer case motor but it’s still locked. I know with all wheel drive vehicles it stays locked but I mine is not all wheel drive. Can anyone tell me
If the front drive shaft should be locked or spin freely …
Thank you
FordTechOne
Detroit
Do you have any 4x4 warning messages in the Instrument Cluster? If not, the transfer case is most likely working properly.
These truck are equipped with vacuum actuated hub locks (IWEs). When the truck is running in 2WD, vacuum is applied to the hub collars, disengaging them from the wheel hubs. This allows the front driveshaft and axles to remain stationary while driving in 2WD. After the truck is shut off and vacuum bleeds down, the IWEs will re-engage due to the return springs. So if you’re checking it with the vehicle off, it’s normal for the front driveshaft to be engaged.
W
florida
It’s the 4x4 shaft from the transfer case im referring to …. The IWE’s are working fine.. I just replaced the entire front suspension… it’s the front drive shaft that I’m wondering if stays locked all of the time
GCATX
King Dingaling
Central Texas
Like the man said, are you checking the drive shaft with the engine running? I assume "all the time" means yes, but you can't tell with folks these days. :)
FordTechOne
Detroit
It’s with the truck running and in 2wd still locked ….
Then you either have an IWE system issue (large vacuum leak, failed solenoid or solenoid circuit, faulty TCCM) or the transfer case is stuck in 4WD. If the driveline doesn’t bind when going around turns, it’s not likely that it’s stuck in 4WD. I recommend seeing if DTCs are stored in the TCCM using ForScan.
Los angeles
Thank you
Did you ever figure this issue out?
