signalbobby
- Joined
- Jul 14, 2018
- Posts
- 244
- Reaction score
- 88
I would disagree and say yes they are with resi lines. On driver side to add preload you are pulling clockwise. Passenger side you will be pushing clockwise.They aren’t adjustable when mounted as the reservoir lines and shock tower are in the way of rotating the collar with a wrench.
Spray lubricant into the threads and unbolt the 3 top nuts to allow further travel to release as much tension on the coil.
Go buy an Icon spanner wrench and use the straight end then to make 1/4 turns on the exposed holes where you cant use the fox spanner.
