GEN 2 Anyone Run this SVC Stage 1 Starter Setup??
Dustan
Boulder Colorado
I have the deavers and SVC bump stop kit. Everything lined up and was an easy install. I haven’t had any issues. I wish you didn’t have to grind off the ABS sensor line attachment to mount the bump plate. But they give a spot to mount the line
WillieFlo
WillieFlo
Houston
Dustan, Are you running 37's on yours? Also, are hydra bumpstops not needed on the front?
Peterb
vancouver
so if the op is fairly serious, the deavers and bump stop is permanent but you probably at least want eibach or geiser springs at the front instead of a collar, new shackles would be smart too
Raptor430
Los Angeles
SVC produces some high quality parts, I ran this setup with their billet uppers until my 3.0 live valve shocks came in and it performed very well. I recommend you not crank the CAS system up too high, it will cause the ride to get pretty bouncy up front. I went with the Fox 2.0 ifp bumps.
Jace21583
Ugh... Why would you run collars over springs in the front??? Because svc doesn't make a front spring?? Lol
WillieFlo
WillieFlo
Houston
Wow, there’s a lot more involved than just bolting on that kit.....my head hurts already....crap!
