2019 Magical disappearing coolant
KingKoopa17
Ohio
Curious to see if anything turns up for you. I also have a '19 at 38k miles and just recently filled up my coolant after I noticed it was a bit below the minimum fill line while changing oil. Pretty much in the same boat as you, no noticeable leaks, no oil discoloration, no changes in the exhaust, color or smell. I'll check the items that others have mentioned here that I've missed, but keep us posted.
fordrat
us
Hi I have a 2019 and notice the coolant was a little below the max level, I bought the truck in aug and about late October or November was when I noticed it but I had just used the heater for the first time so I added coolant and it hasn’t changed since I still kept a close watch on everything because I did just get it, it had 28K on it when I bought it but you never know I hope everything works out for you
cmattdvc
Wedowee, Al
Alright guys, I need to vent and to make sure I’m not missing something. I’ve read through many posts on coolant leaks but some remain unanswered from couple years to months ago.
I’m losing coolant somewhere from my 2019 ingot silver fun machine. No puddles, no visible leaks, had it to the dealership and nothing found. They added dye and requested I return after I’ve noticed coolant level decrease…..in hopes that the dye will direct them to the this magical coolant disappearing trick. I’ve seen mention from a couple of people saying they have had similar issues but unless I’m missing what it was, they haven’t said the fix.
Ive seen it mentioned a water pump fixed the issue but , Would a water pump fail and really show no fluid leakage?
Check the turbo lines.. no evidence there.
Even asked service advisor to have the tech check the valley.
On occasion I can smell coolant wafting up from engine Bay Area….i think….
I’m all ears….and eyes, with any suggestions/tips.
Thanks from Thunder piggy
Busted my first post cherry with a problem instead of an introduction.
I’ll work on the intro next
Mine was leaking like that. I was never able to find the leak. But it was the water pump.
SK19
santa Monica california
My 2019 needed coolant top off in 2021 and 2022 , like half a container worth. Those were also the years I drove heavy interstate (Los Angeles to Portland Maine and back).
