Your Raptor and It's Alignment
Deleted member 12951
Guest
I just had mine aligned today. Had my cam bolts adjusted for maximum tire clearance so I could stuff 37's. The alignment shop had to pull the tire back in order to get the caster back and now I'm rubbing.
Sounds like most of you guys are letting caster go up for better tire clearance.
You want them further forward to clear the back flare. An aftermarket UCA will do that but you can also do some more with the rear LCA mounts.
schmeal
Reno, NV
I have glass and an upper with heims. I can pretty much put the tire where I want. With cam bolts adjusted to push the tire all the way forward, you'll hit the front fender mount before you touch the firewall (with pinch welds hammered).
My questions is more of "how much caster is too much caster?"
Guest
I am in the 7's on caster. Where is your caster at when they said they had to get caster back?
schmeal
Reno, NV
I was right around 6 deg before I took it to the shop. They were trying to get it down in the 4's per the spec they have. Here's my sheet.
attachment.php
I did a "garage alignment" before making the appointment. Looks like I should have just ran with what I did.
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
@schmeal at 4 if you take a hard landing you will tear in to your fender liner. Ask me how I know about that :)
I actually thought Rick was at 5.7-6 not 6-7 on caster. Nothing bad will come from going that high. For me 5.7 was enough to clear my fenders so I'm OK for now.
Are you going to run Pony Express with us this weekend?
Guest
attachment.php
Yep, would of stayed with caster in the 6's, especially if you have UCA heims.
schmeal
Reno, NV
I'll be there as long as the truck is functioning. It's pretty stupid of me to get the truck done a week before the event. I'm kicking myself for not allowing enough time for a proper shakedown.
---------- Post added at 02:42 PM ---------- Previous post was at 02:39 PM ----------
I called the shop, they're going to crank it up to 6-7 like you have. Thanks for the numbers!
JLAKE4130
Phoenix AZ
Rather then start a new alignment thread,
I spent most of the day having my alignment done yesterday. I did Mid perch mod in the morning and dropped the truck off that afternoon. After 3 tries with the tech my steering wheel is still just to the right of center ( In his defense, im super OCD about this). Id much rather correct this myself if possible.
Since the steering wheel is facing right (passenger) cant i adjust the passenger tie rod OUT (say 1/8 -1/4 turn) and the driver side tie rod IN the exact amount? It would be easy enough to paint pen a line across the tie rod, lock nut and tie rod end to know how much im moving everything. Is this how the alignment shops center the steering wheel? If not then how?
Thanks,
