WSI lightbar rack
Deleted member 12951
Guest
Bump...
Any thoughts regarding DDSMECH1's idea of a "custom plastic spacer in the shape of the rail grooves"?
Actually my comment. Yeah I would still like something and would be happy to try something out. Wonder if just a rectangle thick piece of rubber would do the trick?
RaptorScrew
Oronoco, MN
Problem Fixed... "All Else Fails, Read the Directions..."
Had a few drinks tonight and didn't pick up on that until you mentioned it... Thanx...
RaptorScrew
Oronoco, MN
Thanx Huck.
That seems to be able to do the trick. One would just want to make sure they've got a steady hand when it comes to the Router. At those prices there is little room for error... =)
Guest
Negative you can get Teflon block from McMaster Carr, grainger etc. comes on variety of shapes and thickness and length, it has low compressibility, it'll hold several hundreds of pounds. Comes in black or white typically. It's soft enough for regular cutting tools. A router table saw etc,
Measure the gaps on the bed. Setup a strait edge and set the depth of you router blade and do it.
Your over thinking it
Huck, if you make it, I'll buy it.
Huck
Chicago Sw Burbs
I can mill it in a few weeks. I'm in the fatherland for a while
I had cut rubber for mine, but might go this route instead actually.
Labraptor
Illinois
Can easily be done. Just get some black Teflon and a router and get at it
Just a thought/question. Why Teflon instead of HDPE or some other more reasonably priced and easily machinable material?
---------- Post added at 12:27 AM ---------- Previous post was at 12:24 AM ----------
Thanx Huck.
No need for steady hands. Jig it and use a router table or even cut grooves on a table saw. At the price of that material it would be cheaper to make it out of ironwood or a similar imported wood. I know wood on a truck sound silly but you really won't see it much. Besides if you have ever used it you would understand why it got the name ironwood. It will outlast the truck in the elements.
