NickPic83
Still loving mine, just had mine offroad last weekend and they performed awesome even with the stock fox shocks.
Yup my RPG Stage 2 and WSI HD leaf springs get installed Tuesday. Can't wait to see the difference it makes.
Just FYI, the bolts on the WSI are going to hit the RPG kit. On the driver side you will need to turn the bolt around so the threaded part is facing out. Be nice if you could notch a section out before installing. Also get some AMSOIL metal protector and spray the wsi springs really good and let then dry before installing otherwise all the parts rust including the u-bolts.
And if you off-road hard, be prepared for the plastic spacers to come out (happening on both sides):
My HD springs didnt come with the bolt you are talking about.
I will take pics later and show you
Keith and I both got the first set without it for that reason with the bump stop kits.
Good to know, thanks! @RDFTS you got a pic of this by chance? The bolts and where it hits the kit? So if you face the bolt outward does it still hit the RPG frame kit? Any way to prevent it and where does it hit? I just ordered 2 cans of the Amsoil HD Metal Protector BTW.
I wasn't even aware that there was an offering without the bolt in that spot. Is that something new? I got mine in June. Just incase what I meant was to turn it around so the threads aren't the ones hitting since its longer and will make it hard to ever screw off.
