Working on some paddle shifters.
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Subscribing.
I would definitely be interested in a set. I would prefer wheel mounted to column mounted if that is possible.
This or I am going to investigate a gate shifter.
Doc Constantine
SoCal
The ones from mastershift only worked on the 2011+, assuming yours will be the same, or is there a chance for the 2010s?
2010's don't have select shift, so it's highly unlikely we'll ever see anything like this. On the upside we can install a winter's shifter like wiz1500, and I plan to.
downforce137
In Diana
Has anyone tried modifying the shifter so it locks into M? mine locks into D or 2, but will slide either way out of M into the next slot.
M3toSVT
M3toSVT
One of the reasons I hated using the shifter as I found myself shifting into 2nd a couple times. If I break into the shifter I will take a look.
---------- Post added at 07:36 AM ---------- Previous post was at 07:34 AM ----------
What doc said. Need select shift.
405
Bourbonnais, IL
paddle shifters would be great on the raptor. i had them on my m3's and they would really add to the truck. look forward to seeing where this goes!
M3toSVT
M3toSVT
Small update. Just messing with the design of the paddle to spice it up a little.
Took a few ideas from one of new raptors paddles shifters and will work from that. (Shown below)
Also just stuck the model on a generic steering wheel to get an idea of what it would look like.
Next plan is to laser scan a 3d model of an actual steering wheel to get a much more accurate representation of the install and figure out the ergonomics.
