Working on Front end and deavers questions
EZDA45
Victor
Hey guys. First post on here but have had 2 gen 1s. Last weekend I replaced a ton of suspension components on my new gen 1 including Rebuilt shocks at all 4 corners, geiser springs, OEM UCAs, Inner and outer tie rods, and deaver leafs springs. The truck feels much tighter but alignment shop says they’re still having trouble getting a perfect alignment saying something may still be messed up. I’m guessing Rack and Pinion? Also for anyone whose installed deaver +3 have you experienced that you notice more little bumps and a stiff ride? Install was 100% done right. Any help would be great and thanks in advance!
E
EZDA45
Victor
Welcome to FRF.
Deavers will take some time to brake in. You did torque them on the ground, correct? What are your tire pressures set at?
How many miles on the truck? Have you replaced the ball joints and tie rods? Doubt that the rack is your alignment issue.
Thanks Nex! I figured the deaver will need to settle some. How many miles do you think? I did torque everything on the ground but have been contemplating retorquing them. Would it be fine to loosen them and retighten while never jacking the rear up? Fronts are at 35 psi cold rears at 32 psi cold. All tie rods and ball joints have been replaced on both sides mine the ones on the LCAs. 107,000 on this truck. Previous owner had it jacked up on top perch hence all the worns parts I replaced.
Chewie
Central Texas
After I replaced all of my steering and suspension components on mine, the alignment shop I’ve been going to for years had issues aligning mine as well. It came down to the PITA lower control arms with the slots for adjustment.
Got the SPC alignment kit waiting to get installed when I get time. Which will solve that issue.
E
EZDA45
Victor
This. OP, you need a slot delete kit.
Cool, the one from SDHQ right? Thanks guys!
Chewie
Central Texas
Yes but I just got the standard hardware ones. As for instal here’s a video off the tubes for reference
FishFreak
Sacramento, CA
Hey Nex;
The LCA slot delete kit is when you're eliminating any LCA adjustability at all, for, like when you've got the adjustment going on in the UCA with aftermarket UCA's, right? Looking for clarifying because I'm about to replace everything wear related up front with my 140k 2014 Screw, and my new LSK offroad ucas do not have any camber adjustability, so I'll have to rely entirely on the lca cam kit, I guess?
To the OP, EZDA45, and the rest of you, thanks for bringing this up, and the SDHQ alignment cam setup! I'm doing similar to you, and I figured I'd go cheap on the alignment cams, and I got these off Amazon for $35:
Now I can see that the SDHQ cam setup uses a special bolt that rotates both of the alignment cams with the bolt. The cheapos only adjust on the nut end, I guess the bolt end just floats in space? If anyone has used both, please let us know the SDHQ/Amazon el cheapos difference (which, btw, had very high ratings) since there's a huge price diff...? I have a few days to return them ;) !!
Staff online
97,027
60,956
devildog0621
