Wobble when Stopping
R
RAG13
Does the ADD bumper weigh more than the stock unit. Sounds like it’s front heavy.
Good point, but I changed my stock bumper on my '14 to an ADD with no issue.
I did the 2" front leveling and the ADD bumper at the same time, so I'm not sure which one is the cause. I hear people do leveling kits as well as aftermarket bumpers all the time, and I never hear of any similar issue.
I had the truck aligned today and the "toe in" was off so that was corrected. I'm still having the issue. When I stop, I feel like I'm driving an old Caddy with bad shocks!
Jeff-Ohio
Cincinnati
When I come to a complete stop, the whole trucks seems to shake once or twice and then stops. Its almost like a vehicle stopping that had bad shocks.
IF the electronics on the new shocks are not working, would that cause the wobble he is talking about? Similar to a truck with bad shocks? Sounds like he has a connection (maybe fuse) issue causing multiple problems. I wonder if the truck is throwing codes?
R
RAG13
Only codes it's throwing is for the ACC and the fact that it's not available and the warning.
R
RAG13
Finally discovered the issue!! When the truck was leveled the driver side height sensor cable was not connected properly and therefore led to the "wobble" and loss of driving mode availability!
Word to the wise... DONT RUSH YOUR MECHANIC when he's working on your truck!
