Madcowranch
Genetically Modified
Intervention time?
I told you. I don't have a problem. It's everybody else.
Intervention time?
Dont yell at me.
So I got this wiring harness from alternative off road along with my 50" Rigid E series. Honestly just looks like a cluster **** to me. I know the AUX switches have their own fuses, so where do i cut this ****** up and attach it to the switch wire. (picture shows it connected to the bar up top..)![]()
The purpose of the harnesses supplied is to cover every scenario needed. We already have switches, relays and fuses if using the aux switches in the cab.
With that said, cut the wire right before it meets the relay. The only wires you need are the hot and ground (red & black). So follow the wiring down from the light bar, down and the first thing you get to in the harness is the relay. Cut your wires before that.
That is IF you are using the factory aux switches.
