I think it's more "played out" online rather than in real life. I see a ton of Raptors around the Houston area most being stock and the modded ones being black. I've come across 2 bronze wheeled Raptors not including mine since I put my set on.
One of them was probably mine. When we had stock bumpers and BD lighting, it had Method Con6 on OEM rubber. When we added the ADD Bumpers, we also added VenomRex 601 wheels in bronze.
I originally wanted the avalanche with bronze but I wanted a 2018 so ended up getting white with bronze. I love the look. I went with 0 offset and now I’m having some rubbing
Truck looks great and we ran the exact same wheels/tires at stock height with slight rubbing at full lock. You can either trim your inner fender well, about 1" vertical x 2" horizontal, or throw on a set of perch collars and get an alignment. I'd recommend the RPG 2.25" version.
2017-18 Raptor Spring Perch Collar
