Wifi
Frypie
I am supposed to be getting my truck in Feb. Do these trucks have the wifi hot spot?
Mark986
You can get wifi in the truck. So you can connect to a hotspot if that's what you mean?
Ballistic
Oregon
From what i understand the "wifi" option on the trucks now is to connect it to your home wifi for software updates.
Why would you want a hotspot in your truck that would cost more, basically it would be another SIM card and at least another 10/month to your phone bill, when you can use your phones built in hotspot.
UPRAPTOR
hotspot
I believe it does, I have a modem in my truck that works with ATT iT has an ESN # hooking it up for $10 on my plan.
BajaFred
If you don't need it, you don't need it but doesn't mean it works for everyone
I run a cloud connected dash cam, built in wifi is a must, can't rely on other drivers manually pairing their phones each time
---------- Post added at 08:54 PM ---------- Previous post was at 08:51 PM ----------
Can you post pictures
Ford issued a press release just 2 weeks ago that LTE based wifi hotspot wasn't coming until select MY18 vehicles
UPRAPTOR
Onboard Modem Serial Number (ESN)
xxxxxxxx
go to settings,swipe to next screen, then vehicle.
different number then sirus
BajaFred
xxxxxxxx
Thank you, but I meant where you're actually running it as a hotspot and can connect your phone to it
I wasn't able to do it on mine, but Ford has been known to slip in different hardware
I suspect all you're seeing is the hardware that's closed that allows the truck to use the FordPass app ie start from your cell phone, etc
UPRAPTOR
asked my dealer about it and said I could! Im reading it can be done through your phone or USB modem? Maybe the modem is for fordpass only.
