Who is running 37's and what did you do to accommodate them?
Pacific Wheel
Reno, NV
Thanks for the info. I don't remember what offset you have for your wheels, but mine are 1mm offset, and my icons are already at the full 2.25" and I am still getting rubbing on my 37's. I still need to check my actual measurements on what I have now. Today may actually work for that since this is the first day without rain since last saturday here.
Unfortunately the +01 on 9" wheel with a Nitto (which run fairly true to size and sometimes wide) the only options are higher offset or cutting like stated. If you go to a good shop they should be able to trim and keep it very clean.
I'm running the stock BL wheels (+34) so I shouldn't have near the issues you have when I go 37s.
If you stick with a BFG or a Nitto Terra G2 you should be just about rub free. I think the G2 has a little more room and this setup didn't rub on the G1's. The higher offset and tires that run a little small will help for sure though.
crash457
I'm Batman
St. Louis, MO
Yeah, I have a lot of room. I plan on going with either General Grabber X3s, Toyo RTs or Nitto Ridge Grappler so I will probably need to trim a little.
ChevyChad
ChevyChad
37 MT's on stock SVC 17's at mid perch. no issues, no cutting.
So by "mid perch", i assume you have a gen 1? Not really pertenant here for this thread. I had 37's on my gen 1 and was able to alleviate all rubbing with only minor trimming (mid perch). The gen 2's seem to have a bit less wheel well clearance. At least in the front anyway.
