Who has the best aux light install
Antho
Gotcha, I kind of though that.
Thanks.
Also, If you want to avoid having to pin the connector there is a Ford pigtail that comes pre pinned. It is part number WPT-1547. This is the male connector. I dont have a motorcraft pigtail part number for the female side.
If you want to buy the connector and pins yourself. The Molex part numbers are listed below. I use Mouser or Digikey but there are numerous sites.
The molex female connector is 33472-1301
The molex male connector is 33482-6201
Molex male pin 33000-0002 (Loose Piece) - 18-20 gauge
Molex female pin 33012-2002 (Loose Piece) - 18-20 gauge
rkwjunior
Massachusettes
Good info.
I'll look into the ford connectors.
If I do decide to pin it myself I have to get different size pins for the different size wires, or do they cover 2 or three sizes? I noticed the wire size difference for each auxiliary switch.
I was looking last nite.
I need the tool, the pins etc etc. Seems like a PITA. But I guess if you want it done right,gott pay to play.
Edit.
Can I come out the light side with 14 gauge pins, or do they have to match the truck side?
Or I could just get 18-20 gauge Deutsch pigtails.
wheelman55
Big Bend or MN
I soldered a short length of either 14 gauge or 12 gauge stranded to extend my AUX and pass through wires. I put the deutsch pins/sockets on these extension wires. This way I was able to use one size of connectors.
Tr4ckD4ys
Midwest
I also followed @Kashoggio instructions and went ahead with the Deustch connector install:
For tools, you will need wire cutters/strippers, a Deustch terminal crimper (barrel-style; around $20-$30 on Amazon), heat gun/hair dryer/lighter (for the heat shrink tubing), and a Deustch pick removal tool (for disassembly of the connector, when needed).
For materials, you will need the Deustch connector assembly, heat shrink tubing, and braided sleeving.
Deustch connector assembly: https://www.amazon.com/dp/B00D3S25CC/?tag=fordraptorforum-20
Crimper: https://www.amazon.com/dp/B07KXKK8M1/?tag=fordraptorforum-20
Deustch pick removal tool: https://www.amazon.com/dp/B00O7S43AE/?tag=fordraptorforum-20
Heat shrink tubing: https://www.amazon.com/gp/product/B07QM8249H/?tag=fordraptorforum-20
Braided sleeving: https://www.amazon.com/gp/product/B071JH14WZ/?tag=fordraptorforum-20
How did you solve the grounds? Did you do one 2-pin deutsch connector for each AUX switch hot wire (one hot, one ground)?
4rdFan
Michigan
Nope, I attached the terminal eyelet that came on the harness to one of the ground bolts. Only the hot wires went to the Deustch connector.
Pittbug
Columbus OH
I just bought a set of BD fogs, a pillar lights, reverse lights, and GJ brake light bracket and am planning out the wiring. I plan on trying to do this properly, so I want to pin the 6 aux wires into a 6 pin DT connector, then make a harness for the other side that has 6 x 2 pin DT connectors that the lights will plug into. Would you create a common ground in the harness like the attached illustration?
wheelman55
Big Bend or MN
Pittbug. Recommend you add a relay for each circuit. Much better practice and much safer.
Here’s a pic of my setup. Excuse the dust in engine bay.
  • Soldered 12” of 12 AWG or 14 AWG to aux and pass through wires.
  • Used 6 pin Deutsch DT connectors for aux and pass through wires.
  • I used Deutsch solid connectors. Used the white Deutsch plugs to cap unused connectors.
  • Added relay for BD backup lights (see between the DT connectors)
  • Mounted to an aluminum plate at firewall.
  • Unit to left is a solid state Hellroaring battery isolator for my dual battery setup.
  • Ran power wire for lights from Deutsch pin to relay, then from relay to lights.
  • Use a ground point near where lights are mounted.
  • Either use the Deutsch 2 pin connectors at the lights if you want them easily removable. Or wire direct. I used Deutsch connectors at the light end.
