Dane
Be ready to gawk at the cost of a new camera. I've had to replace mine.I took my truck to the dealership today. They say the backup camera must be replaced. It worked fine when I gave them the key, just the guidelines wouldn't work. Now the camera doesn't work AT ALL. I guess that proves that I need a new camera, huh?![]()
Couple things - you can find the camera cheaper on Ebay. It's easy to replace. Here's the important part. Your Ford emblem is going to break when you remove it - and you have to remove it. So when you buy a new camera, also purchase the entire updated replacement housing. It looks the same, all goes right together, but uses a slightly different emblem with clips that won't break if you remove it. Your other option is to spend slightly less and just purchase a replacement emblem which will also break if you ever remove it again.
