I plan on buying a 2022 GEN 3 Raptor (37 package) and want to replace the stock wheel and tire set up. I will use the truck on freeway and city roads only, it will never see a mud puddle let alone go off road. Some may ask why am I buying a Raptor then, my only answer is because I want it and think it`s the best looking truck out there (my opinion). My question is will the new wheel and tire set up listed below work with the stock suspension set up and if not what do I need to do to make it work? Hopefully I would only have to do a leveling kit if anything. If I`m understanding correctly the 37 package comes with a +30mm Offset which would mean my +12 offset would push the tire out 18mm (0.708661") not very much. BFG list the stock tire at Overall Diameter 36.5 and Section Width 12.50" so the new tire is 0.27" taller and 1.08" wider. The tire would be heavier by 24.18 lbs. I`ve tried to do my homework but I`m no expert, that`s why I need your help. Thanks for your time guys.
Tires/Nitto Ridge Grappler
TIRE SIZE
37x13.50R18LT D
Overall Dia (in) Inflated Dimensions
36.77
Overall Width Inflated Dimensions
13.58
APPROVED RIM
9.0-(11.0)-11.5
WEIGHT
89.02
Rims/BLACK RHINO MESA
Size / 18x9
Offset / +12
Back spacing 5.470
Weight 35 lbs
The pictures are the wrong sizes, just to give you a idea of what I`m going for
TIRE SIZE
37x13.50R18LT D
36.77
13.58
APPROVED RIM
9.0-(11.0)-11.5
WEIGHT
89.02
Size / 18x9
Offset / +12
Back spacing 5.470
Weight 35 lbs
