Wheel and tire advice
thatJeepguy
GA
The gen 2 used market crashing is really putting the forum through its paces. At some point “ everyone was a noob once” has worn out its welcome. Its almost satire at this point. Hey could be worse, at least its 38x12.50x17.
Ill add OP: ypu are running whats known as “poor mans bead locks” at that smaller rim size you have more stability / pressure against the rim . When you air down you will see that your bead is in better shape and harder to come off in higher speed lateral movements like in sand etc.
