What wheels and tires are you guys running?
RamseyF
michigan
I finally got home and was able to snap some pics. Fuel Vapor. 20x9. 19 offset. 35x12.5x20 ridge grapplers. my everyday wheels and tires. off-road ones I put back on the stock. wheels and tires so I have more sidewall to go with.
mikehawncho
My Head
17x8.5 Method Grid with 35” BFGs
RamseyF
michigan
Dont forget when you change the stock wheels which are 8.5 wide to a different width wheel adjusting the offset is required if you want it to be close to stock. when I went to the 20 x 9' I went to a 19 offset. its about overall 1/2 inch out farther than stock.
nikhsub1
Los Angeles
It would be more than 1/2". Stock wheel is 8.5 and 36mm offset? so you are 1/4" just from the 9" wheel and if I'm right and the stock wheel is 36mm offset then you have an additional 17mm + 1/4" so probably just over 3/4" or so. Not a big difference though.
LuckyKnuckle36
RIP CoronaRaptor
MD
Well my icon rebound pro's 17 x 8.5, +6 offset titanium arrived today from my Black Friday purchase. Now I just need my truck to get here!
CVP33
Florence, SC
Venomrex on 35 x12.50 17
*Note to self - I need to man-up and pull my Raptor decals off.
Wheels - 17x9 +12 offset Vision Korupt 32.7lbs.
Tires - 315/70r17 (34.4” O.D.) Goodyear Territory 55lbs.
*87.7lbs. per corner versus 106lbs. for the OEM forged wheels + KO2’s
*Saved 18x4 = 72lbs in unsprung weight
