What Tune you like the most?
GooseTuned
New Mexico
You want to go there? Okay let's go there. Let's dispel some myths on a few subjects. I will address pump gas tuning here, because we all know using higher E blends makes it easy to produce big power safely......
You talk about heat soak. The biggest contributor to heat soak is ELEVATED BOOST! When we tuned the first raptor back in 2017 we had lots of experience on the ecoboost platform previously and we tested our raptor for a 6 months before ever releasing to the public. We quickly found that the turbos would reach their design speed limit of 220000 rpms very quickly so we stopped boost there and thus the reason we limit boost at that level first and foremost. Timing actually keeps things cooler in boost so your cats don't cook as we actually measured cat midbed temps on the dyno to verify this is true. Lots of boost and no timing = hot cats! You even melt a cat? It is easy to do.
Obviously you don't understand how our auto octane feature works. It is a similar way to the way the factory does it (but different at the same time) and takes months of development to make it work like ours does. Instead of just running the same boost all the time no matter what the inferred octane is, our calibrations will run full boost on 93 octane (actually 91) but if it can't run enough timing it will ratchet back the max allowed load somewhere between stock and the premium fuel levels to save the cats. It doesn't ride the knock sensors like you are insinuating. Our calibrations will be + or - 2 degrees at all times on the KR activity but sometimes the knock sensors add more over the base calibrations where the trucks are detonation prone. Once the "long term timing trim" also known as OAR adjusts for inferred octane, the calibration automatically changes the maximum boost allowed. This gives maximum safety for anyone running our calibrations even if you think you are getting premium fuel and the station owner is cheating when they have a few hundred gallons of cheap stuff left and just dump it in their premium tanks.....
Even with the auto octane features we employ, we even felt the need to improve intake temperature compensations so that when you sit in traffic and gouge on the loud pedal you don't get crazy KR before the intercooler has a chance to do its job. We spent a whole lot of time working on the base calibration behind the scenes before we even started going for max power. This way the customer ends up with a reliable, fun truck that they don't have to watch their data screen on their tuner like a hawk the whole time they are driving. Also the customer won't have turbos that die a premature death from constantly being overspeed at wot from running too much boost....
Matt
www.ghtuning.com
I understand the strategy.
My point in saying what I said was there are many ways to make power. Whatever works best for you or I are what we use. Thats why I love tuning so much, there are so many different ways to achieve the end goal where engineering principles and creativity happen.
Higher boost can cause heatsoak, yes. And more ignition timing will cause higher cylinder pressures. Give and take..
With 40,000 HARD development miles on my personal truck I have yet to see anything like that. My cats are also fully functioning, even at 500whp.
10SpdsOfFury
Jacksonville FL
Matt
www.ghtuning.com
Hey Matt a quick question. I was watching the videos on the Ora550 tune and was wondering since I have the whipple IC and CAI and not the Cobb stuff does the tune need to be adjusted very much or does the Cobb and whipple stuff preform about the same?
mattr66
Bryan, TX
Yes we have had a lot of miles on our development truck with our turbos on it as well. EPA requires 100K worth of emissions life on components. Questions will be asked one day on how cat temps are being managed. It is just a matter of time.
mattr66
Bryan, TX
Similar but different, there is a little more pressure drop on the Whipple vs the full race and Cobb intercoolers. It can all be adjusted for.
GooseTuned
New Mexico
Believe it or not, fueling can be utilized to combat excessive cat temp! (just like the OEMs use)
Just another way to skin a cat :)
