What springs to run on Gen 1 with Gen 2 shock and bucket conversion?
Speedhunter
St. Louis, Mo
Hello,
I have a 2010 Raptor and I recently purchased some Gen 2 shocks. I want to do a front bucket conversion to fit the new shocks.
I'm having a hard time finding what springs to run. What are your experiences?
Things I have found out so far:
- OEM Gen 1 springs are shorter than the Gen 2's and have a higher spring rate.
- OEM Gen 2 springs are longer than Gen 1's but have a lower spring rate.
- The OEM Gen 2 springs also look larger in diameter. I've seen a person try installing Gen 2 shocks and springs on a Gen 1. Due to the diameter, the OEM Gen 2 spring would hit the frame and a couple of other places. I've only seen one case of this so far.
Jhollowell
Everett, wa
i think you need to stick with the Gen 1 spring unless the gen 2 top hat is compatible with the new coil buckets. you may want to look at re-valving the shocks too as they are probably a bit soft for the gen 1 (heavier) truck especially with the stiffer gen 1 spring.
SilverGen1
Midland MI
I have done this, and I stuck with the Gen 1 Eibach Springs, I had no clearance issues that weren't present with the Gen 1 Shocks and Springs. I haven't revalved them, they perform well, I'm sure they could be better
Speedhunter
Speedhunter
St. Louis, Mo
This is great to hear!
So all the parts of the shock you are using are Gen 2 except the spring? Gen 2 top hat?
blueherron96
Michigan
I just got my gen 2 FRS shocks in and they will be sent out shortly to be revalved for the heavier weight of the gen 1. They came with a 18" long 550lb spring and I will be replacing it with a 18" long 600lb spring from eibach.
Not sure how this carries over to the factory shocks but I think I've seen people run gen 1 springs on oem gen 2 shocks.
SilverGen1
Midland MI
Nice this is a great deal of help! The new suspension set up looks awesome.
Thank you!! If you have the time/patience/cash I would send your shocks out and have them revalved for sure, I would be curious to see the difference it makes, or if any other suspension gurus in here know the difference in the valving between gen 1 and gen 2 and where everything sits on a gen 2 converted gen 1
pat247
Oklahoma
Hello,
I've been running the Gen 2 shocks on my 2014 Raptor for 5 years and 65k miles without any issues. I used the Gen 1 spring, spring hat and angle wedges. The Gen 2 spring hat is identical to the Gen 1 but has shorter studs and won't work with the angle wedges. The Gen 2 spring is larger in diameter and hits in a couple places as you mentioned. Do a search on my screen name to find my writeup on this subject. This is the best mod that I've done to my Raptor.
