What springs to run on Gen 1 with Gen 2 shock and bucket conversion?
SilverGen1
Midland MI
I've been running the Gen 2 shocks on my 2014 Raptor for 5 years and 65k miles without any issues. I used the Gen 1 spring, spring hat and angle wedges. The Gen 2 spring hat is identical to the Gen 1 but has shorter studs and won't work with the angle wedges. The Gen 2 spring is larger in diameter and hits in a couple places as you mentioned. Do a search on my screen name to find my writeup on this subject. This is the best mod that I've done to my Raptor.
You kept the wedges in? I removed them, and now a couple other people who have done this that did as well. What was your reasoning for keeping them? I don't even know why I got rid of mine
Speedhunter
Speedhunter
St. Louis, Mo
I've been doing some more searching and I've come up with the following.
1- Gen 1 and Gen 2 top hats are identical, except for Gen 1, which has longer bolts for the wedges.
2- If you do the Gen 2 shock swap and keep your factory Gen 1 buckets then you will need to use the Gen 1 top hats and wedges.
3- If you do the Gen 2 shock swap and also swap out the coil bucket then the wedges are not needed and you can use the Gen 1 or Gen 2 top hats.
Most people I've seen prefer to run the Gen 1 springs due to their higher spring rate, despite being shorter than the Gen 2 springs.
pat247
Oklahoma
The reason I kept the angle wedges was because the engineers at ford felt they were needed. They set the proper angle to the I-bolt in the lower control arm and keep the spring away from the frame rail.
SilverGen1
Midland MI
Yes, doing some research of my own, the KHC buckets at least, and I would assume the other buckets, are already at the correct angle, with no need for the angle wedges. I WOULD NOT advise just shoving the longer gen 2 shocks into the stock gen 1 buckets, that is not the correct way to do it. The only way to do this would be to have the shock shaft shortened up, but then you're only upgrading from a 2.5 to 3.0 coilover, and not gaining any additional travel.
SilverGen1
Midland MI
The KHC Conversion Bucket does not require the use of the angle wedge, as the bucket is already at the correct angle. I'm assuming this is the same for the other conversion buckets out there
Speedhunter
Speedhunter
St. Louis, Mo
It's been pretty interesting.
I've seen members do it both ways with and without the bucket swap. Due to the variations, I've been trying to come up with the best way to install them.
I agree it is nice to gain the additional travel by doing the bucket swap and no longer need to use the wedges. I'm going to go this route.
Speedhunter
Speedhunter
St. Louis, Mo
My next biggest question is if you do the bucket swap and use a Gen 1 spring. What is the best route for ride height?
Because the Gen 1 spring is shorter I'm pretty sure this would lower the front of the truck with the bucket swap.
To gain ride height you would have to use either:
- Aftermarket Gen 1 springs like Geisers or Eibach's
- Use the Gen 2 perch collars
- Or a RPG / SDI top hat with lift built-in
SilverGen1
Midland MI
I am running stock leafs in the rear end with Gen 2 Shocks, KHC Conversion Brackets, and up front Gen 2 Conversion buckets from KHC, Gen 2 non live valve with Eibach springs up front paired with RPG's 1.5" perch collar (for gen 2 shocks obviously) and this is how my truck sits
mtnghost
california
A little about how shocks and springs work and you can decide for yourself what to do with the info. First off springs are designed to deal with the weight of the vehicle. There are different spring rates and types out there, geyser progressive, Eibach linear. So first gen needs first gen springs. Sure you can jam a second gen whatever in there but it is not made for it. Next is valving. Valving has absolutely nothing to do with the trucks weight. Valving is designed to dampen the forces that the spring creates. So gen two shock needs to be revalved to whatever spring you are using. A good shock rebuilder or tuner would have a shock dyno, and use it to get working data and reshim the shocks accordingly. The top hats have been covered, the shock shafts are no different, but the bodies on the gen two are longer. This causes the internal bypass to become an issue due to where the tunes change in the shock body. Again it works but is not tuned to the spring. The aftermarket springs negate any effect of shorter gen one factory springs. And that’s all I have. Good luck, I will at some point in my life do the bucket swap and install aftermarket gen two coilovers and I have also purchased the rear shock extenders to ensure the suspension stays balanced.
Members online
97,067
61,001
OffroadWagon
