what limits the rear travel?
khcdave
South Brunswick NJ
Rubber bushings in the stock shackle limit ur droop along with shocks but most of the time the shackle is the limiter. Rubber spring bushings are also a contributor Jack up the rear from the frame and u will be able to push the rear down usually a 1/2 to 1 in depending on the spring u are using. Change the bushings to poly and u will get the full travel of the shock at all times.
