TheJoker
Here is a discussion on towing the Raptor: (2010-11 = No, 2012+ = Yes but only after a long ass procedure.) http://www.fordraptorforum.com/f5/towing-four-down-16179/#post219207
No not 100%. But only fools are positive. :rofljest:Two things: Are you certain this is the diff vent? As I stated, I have a 2011 Scab and the front diff vent looks similar, but is located near the master cylinder.
Also, the owner manual clearly states that the vehicle should be transported on a flatbed. If they towed it without dollies then they may have damaged the IWE. Not Good!
Rookie look at your diff see if there is a hose hooked to it.
No hose connected to it. I assumed that it was probably the diff thing but I couldn't locate the dif vent.
You need to get this fixed. H2O causes huge problems... So I've heard.
OP - How many miles (approx) was it towed for btw ?
