What is the highest quality, best cooling, stock location Intercooler?
BroncoAZ
Cape Cod, MA
By the way I am not bothered by this thread actually thankful for reading it . My raptor is bone stock. the IC seems like a good way for more easy HP without other mods
I agree, it's very timely for me to have a fresh thread on intercoolers since I just bought my Raptor and live in Arizona where it's balls ass hot. it seems like a mod that an otherwise stock truck could just really benefit from.
saym14
Prescott AZ
agree. I don’t really want to flash it or anything else. I will want it to be able to be easily converted back to stock if necessary… I don’t want to cut or remove things or change my front bumper. Does anyone know what the horsepower bump would be?
By the way I am and easy to but I am in a Prescott it’s probably 20 or 30° cooler than where you are?
BroncoAZ
Cape Cod, MA
I live in Flagstaff where it’s nice and cool, but I drive to the Devil’s ******* known as Phoenix way more than I want to.
smgilles
There is no horsepower or torque bump from an upgraded IC. They help prevent "heat soak" from running WOT or towing, etc. People typically upgrade their IC because they are "flashing" the PCM with COBB, JDM, MPT, etc, etc....
Ali 556
Home
To OP,
keep your charge intake temp BELOW 50*c, anything above that the ECU will pull sooo much timing it will be like a -150whp truck.
saym14
Prescott AZ
Thanks. Good to know
nikhsub1
Los Angeles
Depends on how you look at it. If the OEM IC causes timing and boost to be pulled back by the ECU because of high intake temps, and that pull results in 40 less HP vs a good intercooler where there is no pulling of boost and timing.
smgilles
That's fair, it may prevent a deduction of hp/tq, but I still stand by the statement that it does not add any either. I think the stock IC is hot garbage and everyone should updgrade. It takes 2 hours of your own time, especially with the plug-n-play models (CVF, whipple, etc...).
