What did you do to your Raptor today? (Gen2)
Nex
RIP CoronaRaptor
Washington State
So you just have the rings on top of the wheel and not locking the bead? I am confused because you went back to discount to have them pop the bead.
gr8scott_o
Mile High
No... In order to pressure test, they mounted the tire normally. Then they popped the front bead off and gave me the rim back so I could remount the ring.
wbraptor
Michigan, USA
Fixed my sagging drivers seat. My raptor only has 14,000 miles and I’ve owned it new from day one. I noticed the drivers side seat was sagging, I have a great Ford dealership that does all my warranty work. It’s so refreshing to have a service department that bends over backwards to try and accommodate their clients. I have a handful of cars from various manufacturers and my Ford Dealership service department is by far the best. It’s extremely refreshing.
Initially, I only asked for the seat cushion to be replaced, but my service advisor thought I should replace the seat cover because of the wrinkles in the leather as a result of the sagging, so he took it upon himself to submit a warranty claim for both. Here are some before and after pictures, including the new seat cover..
Amazing how much more support I now have…
How were you able to get the carbon fiber center console/shifter trim surround in that carbon finish? Did you buy it done or get it dipped? I really want to do this. Please advise
JorgesRaptor
Seattle
Todd Turbo S
Nor Cal
Here you go. It’s a bit tricky installing. You’ll need to remove and reinstall the inner metal trim. I made the mistake of leaving it off, had to remove the CF center console after I installed and ended up braking one of taps and had to apoxy to fix. Looks good though. Nice quality but not a perfect match to our OEM CF
Pistol_Pete
Arizona
Got back from 7 hours of hardcore off-roading. Mostly saw side by sides. Cleaning her off I found my glass had been etched by the fine dust. I tried a Dremel helped but left marks. Decided to try McGuire’s fine scratch remover. Worked like a charm2DBC3908-2960-4C41-8BF5-1A2E15F4E25B.jpeg
