How do you find the output as compared to the stock headlights?
Been working on installing my @OffroadAlliance.com triple bezel kit. Just need to get them wired up and aimed now. Driving/combo inside, SAE in the middle, and S1 wide cornering ambers on the outside.
Too early to say - last night they were pointed straight down. I had to adjust them at my trusty wall a few blocks up from my house, only drove a couple blocks so far with them adjusted properly. Let's just say they are crisper than stock but I live in Hollywood so street lights are everywhere... I will report back with more night seat time.How do you find the output as compared to the stock headlights?
I was going to get them, but they were out of stock and said they would be for a few months. I'll get some whenever they are back in stock.Exact same set up as mine. Your really going like them. ORA is the best. Did you install the optional back covers for them? If you didn't I highly recommend them. They're worth the extra time to put on. It really cleans up the install and protects the back from mud and debris.
Sent from my IN2025 using Tapatalk
For me, getting the bezels on was a PITA. The lights go on pretty easily once the bezels are installed. I can tell you I ended up using the following spacers and washers:Will be installing the exact same setup this weekend... any pro tips or lessons learned??
Yes. You just have to drill some holes and they provide the push clips to push them in. Pretty easy. I'll post some pics later tonight so you can see.I was going to get them, but they were out of stock and said they would be for a few months. I'll get some whenever they are back in stock.
Can you tell me how they attach? I know they attach to the liner, but how? All I can find online is a pic of the backside, none of how they mount.
For me was having someone hold on to the gasket. When I would tighten the housing down the gasket would get snagged. I would tighten slowly. Once the gasket was in place and could not move out place you can tighten down normally.Will be installing the exact same setup this weekend... any pro tips or lessons learned??
I went back and forth between BDs yellow lens and ORA orange lens to match the factory lighting. I ended up with the BD yellow, but know the orange looks great, too. I may switch at some point if I get bored with it.Nice to see quite a few others putting in ORA bezels too! When I bought the truck it already had the bezels and the amber S1s, so all I needed to do was add the 3inch cubes.
