What did you do to your Raptor today? (Gen2)
Big Blue
Administrator
Staff member
Admin
USA
You a fan of the KO2s in the snow?
Yes. I have found that mud tires suck in snow/ice conditions. The KO2s have great siping and surface area and do an excellent job.
Gdog
Colorado
for those guys who have changed out their rear diff covers quick question. I've been researching whether or not to degrease/ use brake cleaner on the gears when changing out the covers. Some do and some don't. Some say just wipe out the sludge if any and move on while others say to clean the gears. looking for opinions here as I'm doing my cover replacement this week end. Thanks in advance
Zeusmotorworks
Sooooo one mechanics opinion... if using brake cleaner on the gears, what’s being done to relube them prior to that 5500lb+ load? IF I were going to do that, I’d at least manually spin the diff in the lube prior to just jumpin in and driving away with dry metal to metal contact. Granted, the pinion SHOULD have lube quickly, but I’m more the paranoid type.
side note: I’d wipe out the bottom, but wouldn’t spray brake cleaner on the ring gear.
Now waiting for Oldfart’s “lube” suggestion...
Deleted member 17706
Guest
Your not going to hurt anything by using Brake Cleaner. I do it to insure I get all the wear metals off the differential. You will be amazed at how much extra crap you can blast off the unit. It also depends on how old the fluid is and how everything looks.
Fast forward to 6 mins.
