What did you do to your Raptor today? (Gen2)
Lags
California
How much is the goosetune if you already have the accessport?
Ask Goosetuned. Winfield Raglan is his name. I'm telling you all right now... He is the best! MPT, Gearhead, COBB (canned), etc..., they all have their pros and cons, but Goosetuned... Only Pros!!
nikhsub1
Los Angeles
The ones they recommend on the GH site. Ford Performance EcoBoost M-12405-35T Gapped Spark Plugs (0.026-0.028)
Sent from my SM-G960U using Tapatalk
OK reason I asked is there has been confusion since Ford discontinued the SP-542 (old cooler plug) and the M-12405-35T is the new cooler plug. Many thought the SP-578 was the SP-542 successor, it is not, it is the new OEM plug.
ljn21
Tega Cay, SC
The goosetuned products are the absolute best. With all do respect... after buying a $70,000 truck, I would suggest setting aside your concern of a few hundred dollars or whatever the difference you are referring to may be, and pull the trigger. Not only are the tunes he writes the absolute best, his customer service is second to none. I have the Stage 2, and his TCM. ABSOLUTELY LOVE IT!!!
On another note: I filled my gas tank up... and it was cheap. HAH!!
Umderstand but its not a couple hundred difference. Goose with TCM woth an access port is $1620! GH with an X4 is $524...
The m-12405-35t are the 542 plugs, just sold as a kit under Ford Perf name.
nikhsub1
Los Angeles
No, they aren't. It is a totally redesigned plug - if you have an SP542 compare them, you'll see.
nikhsub1
Los Angeles
ljn21
Tega Cay, SC
yeah they are wrong. I guess when they first switched to the new part number they could have been the same - but now they are 100% different. The SP-542 has much more ceramic around the electrode than the m-12405-35t.
Is the temp range the same as the 542s then or is that different now as well? And is the NGK 6510 the same as the 542 or M Ford Perf set?
nikhsub1
Los Angeles
The m-12405-35t is the new redesigned version of the SP-542 - same heat rating (cooler) but they are physically different.
Lags
California
$1096 difference according to the numbers you shared... Worth it...
