What did you do to your Raptor today? (Gen2)
hedonist222
Dubai, Abu Dhabi, UAE
Man I am in this inner debate of going 37's or staying 35's
if you go 37s, do it right for the peace of mind and full experience
I'm putting this out there and I hope you other gents chime in (and probably correct me)
Without having to change final gear ratio on Raptor (assuming this is something good to do with the larger tires /added unsprung weight), maybe a lighter flywheel can mitigate the dire need for final gear ratio?
A friend did this with his yamaha yxz 1000r buggy, after adding heavier tires, a lighter fly wheel remedied some drop in power loss
Rednose
Dubai
Re gear is one of the reasons I did not go with 37’s I know won’t be facing a problem with losing power because of the 10 speed that being said I am still not connived with running the 37’s without changing gears because I don’t air down and of terrain here is mostly soft sand softer than Glamis and with suck terrain and the added weight of the 37’s I won’t have the same power band through tall the gears the same way I do have it now.
So yes 37’s without gears is no for me unless I run them only in summer only and go back to 35’s in winter. And the only advantage I would get is looks not performance.
tplee
South Carolina
I can't imagine a lighter flywheel would help much. I ran 37s on my '14. I loved my 37s at first, but nearly every aspect of the behind-the-wheel feel changed at least slightly. There was noticeably less off-the-line power, but it wasn't as bad as I thought. If it were just this, I could have been okay with it. The worst by far was the body roll and harsher ride. Then there was the significant drop in gas mileage. I went from 13.8-13.9 MPG to barely clinging to 12.1-12.2 (again, this was a '14).
Those things altogether wouldn't have been so bad, except these days I am spending all my time on pavement. It just wasn't worth it IMO.
Circling back to the question of regearing. My bias is toward re-gearing in most cases (I should also point it that I do all my own gear installs myself, so drastically cheaper for me to re-gear). I had a late 80s full-size K5 Blazer with 38.5" Superswamper TSL's and I ran 5.13 gears in that and loved it! When l lifted and installed 35's on my '05 Silverado I re-geared from the factory 3.42s to 4.11s. That was absolutely essential.
Having said all that, I think most will be perfectly fine with 4.11s and 37s.
Sent from my Pixel 3a using Tapatalk
FrenchRaptor
Waay Up North, Maine
Dirty truck???.... I’m with you Mudluvin’.... as often as I am off road and dirty, it makes no sense to try to keep up with keeping it clean. I beat on my trucks and make them work. Scratches and crap on it are just par for the course when it comes to my stuff. Love it
hedonist222
Yeah a lighter fly wheel won't remedy body roll, but my thinking is the lighter fly wheel will support acceleration or regaining momentum after reducing speed or slowing down due to terrain - so with a lighter fly wheel it'll pick up a bit faster than with the stock.
Thinking out loud here...
