What did you do to your Raptor today? (Gen2)
RaptorSRQ
Bradenton,FL
Installed some headlight protection film. Was relatively easy as the headlights are basically a flat surface. Can’t even tell it’s there
RaptorSRQ
Bradenton,FL
Link to the film?
https://www.invisiblemask.com/imask/index.php?route=product/product&path=38228&product_id=133779
I went with the 3m scotchgard pro. They send a squeegee which works really well but I would also recommend getting one that is smaller. I used one I had left over from a cell phone clear protectant kit I had. They show you how to make your own slip solution which is distilled water and dawn dish soap, and a tack solution, which I didn’t end up using. The best result I got was from starting at the upper outer edge of the headlight and working down the outside of the headlight and then move toward the middle. The first headlight I had to rework it a couple times but if you use a lot of the slip solution on the front and back of the film it’s very easy to reposition. I also rubbed down the headlight and surrounding painted areas with an isopropyl alcohol and distilled water solution before I started to make sure any bits of dirt and dust were removed
REMIX
Sarasota & Jacksonville, FL
Not very impressed with them.
If they need $23 for this, then charge $23 w free shipping. Or $20 + some amount that doesn't look insane for shipping. I understand with the larger graphics they make shipping might be more, but this would basically fit in a #10 or small manila envelope. 50 cents to send this USPS.
Johnfaeglasgow
Kansas
theres a company outside of new orleans that specializes in custom powerwheels to match dad's ride. They even set them up to be remote control.
They are wellllllll under 3K.
My daughter is SAVAGE driving Powerwheels... I’ll have to look them up!
Mbdurham
Georgia
Same here! I ended up putting 16” bike tires down the middle on the front and rear “tires”. The plastic had no traction on the grass. There is also a 18v battery mod that looks pretty simple I will do when he gets a little older :)
Dachuri
Memphis & Austin
One of my first mods was actually removing the engine heat trapper.
That’s what the FMIC and 170 tstat are for. Gotta keep it clean under the hood because when you look good, you feel good and when you feel good, you play good.
Just saw the 30 for 30 on Deion Sanders - scientific fact.
