What did you do to your Gen 3 today?
Waterfowler41
Illinois
Sorry all didn't realize how many questions there were, tried my best to answer them below:
That's pretty cool. Did you get any of the installation add-ons or the basic kit?
Yep in addition to the camera kit, I also did the hardwire kit, license plate bracket, and the OEM bracket. I don't think I would install this kit without at a minimum the OEM bracket and the hardwire kit.
I'm looking into that ... how long did it take to install?
Actual install took maybe 30 minutes. Running the rear wire under the truck with it being near 0 F in my garage was a huge PITA and took about an hour. Wire doesn't like the cold weather which makes trying to snake it through the chassis a tad harder. I was also freezing my *** off so had to pop into the house to warm up every few minutes.
Awesome. Would you show what that looks like and how you mounted? I may buy one for that alone.
I show this in my movie which I included in the OP but here's my install. This should help I hope: G900Pro Raptor Install
is the mirror powered via separate power source i.e usb or cigarette lighter? I know the fitcamx in my GX550 is powered with the inline plug to the oem mirror.
Its hardwired to my fuse box. I used the provided add a fuses for a constant and switched lead. I show the exact fuses I use in my video posted ^^. This is where I will say, if you don't want GPS or G shock monitoring and only want to record while the truck is on, the Fitcam is probably the better option because of that inline power dongle and the camera housing looks great (almost invisible). I replaced my Fitcam with the WolfBox because, well...Youtube content... Having had both now, I see use cases for both. Just all depends on what you want from the cameras. Both camera use similar phone apps which are both as idiot-proof as they can be...
X2. The only thing I miss from my GMC is the rear view camera mirror.
I didn't have a digital mirror in my Sierra when I had it BUT I did have a torque converter that would scream really loud at start up. I do NOT miss that! LOL. The digital mirror certainly takes some getting used to. I turn it off at night using the voice command "Turn OFF Screen" which is super dope.
Waterfowler41
Illinois
Thanks for the replies. Is this the exact model?
https://www.amazon.com/dp/B0DD78Y3L5/?tag=fordraptorforum-20 Looks like it's on sale too
Yes sir, like mentioned above, the hardwire kit and OEM bracket are well worth it. License plate bracket is up for debate for the rear camera. The OEM bracket specifically because the Wolfbox mirror does not completely cover the factory mirror so it will look wonky, this would've bugged the hell out of me. The OEM bracket allows you to completely remove the factory mirror and use the WolfBox on its own.
cfmistry
Maryland
Instead of (or in addition to) the hardwire kit could you have tapped into the mirror like people do for those dashcams?
roger7254
Orange County, CA
Installed some Baja Designs LP4's.
-SDHQ A Pillar Ditch Light Brackets
-Baja Designs LP4's, amber backlight
-SPV A Pillar harness. Ran the harness under the cowl and in between the fender where it mounts, towards the A pillar.
-SPV running light harness
-ARP 12pt Bolts and Nuts. The plan was to lockwire the bolts, but I broke the only 1/16 bit I had.
-Used some left over Gray Techflex and Shrink tubing from a KTM wiring project
-4 way zip tie mounts and zip ties. Mounts are under the cowl.
Running light harness routing under the plastic cover
Laying the A pillar light harness location
Prettied up the light harness a bit
LP4's with ARP Hardware(Orange Locktite)
Final Product. Just need to adjust the lights a bit more and buy the LP4 side reflector covers.
LP4 side reflector cover will help. https://www.bajadesigns.com/product...aMDPgkki12oxCT5ktWl_&sku=299208&vid=969431431
