scarrjack
The Park, Alberta
Modified my extra Bakflip cover so I can still run with it on when using my tire rack. Made a cardboard template, transferred it to the Bakflip and started cutting. Turned out pretty good, just need to install some rubber edging to finish it off.
Zeke555
Sherwood Park, Alberta, Canada
Bigger mod
Dude, finally a mod!!! Can't wait to see the pics......
Finally a bigger and more expensive mod instead of the low cost and small ones. Lol.
---------- Post added at 09:29 PM ---------- Previous post was at 09:28 PM ----------
Looks real good @scarrjack. That was a great idea.
Palerider
Looks awesome and a great idea. If I may make a suggestion, you may want to add some type of support for those edges around the tire where the cover reaches the tailgate. I can see that flopping around during off road use.
Sent from my SM-G925V using Tapatalk
scarrjack
The Park, Alberta
I already have a bolt on each corner to hold it down (same type of bolt set up that holds on the front corners as well) so there will be no way that it will actually open up. I will still have to wait and see how much movement there will be as I definitely compromised some of the covers strength by cutting a portion of it off.
Palerider
You da man
Deleted member 12951
Guest
Replaced my seat belts
Had to disconnect the plugs and plug into new housing so now how do you turn off the airbag sensor light in the dash?
2014RubyRed
Galesburg, IL
So, if you yard-dart your truck, you have to change the seatbelts or did something else break? Just curious.....
Jimbo
Mad Frog Mattis
IL
Dealer, most hand-held scanners won't reset airbag lights. @13raptorcrew may have some other secrets to try.
