Hole Shot
Raeford, Nc.
Took delivery of some new shinies thanks rsi works and icon.
Dual fronts?
t_j
Chicago, IL
Dual fronts?
Yep just waiting on the ucas and lcas from camburg and I'm ready to start the install. I'll be welding up the sdhq reinforcements to my new knuckles tomorrow. First I have to make a black Friday trip to home depot to buy some sand and lumber of build a cooling pit, that part is probably gonna suck the most.
Hole Shot
Raeford, Nc.
Nice how are you gonna weld the knuckles? Mig,tig stick. What type of filler metal you gonna use to weld it stainless, nickel? I have a set of reinforcements I just got and I'm deciding what route to go. I just installed lcas a uca's and fox all around. Ran out of money for the second set of fronts. So maybe in the spring.
t_j
Chicago, IL
I have access to all 3 processes. Current plan is tig with 100f preheat and a sand cooling pit. I need to work out if the lab furnace will run at 100f so I don't have to preheat with a map torch.
Hole Shot
Raeford, Nc.
Let me know how it works out
t_j
Chicago, IL
Oh and planning on a mild steel filler as its closer to the base metals. I will be running a 1" weld throwing it in the sand repeating it on the other knuckle then switch get back to the first at the opposite and to the first section.
