NickPic83
Rockland County NY
Hooked up my dually rear lights, wired into aux #4 and relay for auto reverse lights, only regret is listening to ADD and RIGID to use spot,with the angle of the lights in the Dimple R bumper, don't think I would of had camera light wash out, should of used D2-Driving or wide beam.
Looks good but u are right flood is the way to go for reverse aux lights. That's what I did on mine and it's perfect, enough light to see without washing out the camera
Yukon Joe
Trafford, PA
adding second compressor and 2 more gallons of air. that brings me up to 2 viair compressors and 7 gallons total. hoping to be able to run air tools for a short bit with this setup.
Where do you have your air tanks mounted?
Came in second place in the "Cars on the Crest" yesterday...
awesome!
Also added extra aux swithes, being I didn't have a trailer brake controler, I used the pocket for the install, made a bracket to replace pocket, then factory switches snap into bracket, so dash panels can be removed with out disturbing anything or moving, also can be put back to stock , nothing damaged or altered.
Great looking install.
Yukon Joe
www.RUNRAPTORRUN.com
---------- Post added at 09:19 AM ---------- Previous post was at 09:14 AM ----------
Extra piece of mind now. Had rear shock mount gussets welded on.
Did you have to clearance your mount for the king shocks?
Also, did the fabricator reinforce the existing welds on the POS mount?
Yukon Joe
McDowell
Oklahoma
If I put my truck in 4x4 then try to put it in gear it grinds the gears horribly and also will not go back into 2 wheel drive so I am stuck without being able to move unless I roll down a hill after about twenty minutes I can get it back in gear but it was grinding the gears horribly and I had to put in neutral and turn it off a few times to get it to even try to switch gears.
rap67
SE michigan and Arkansas
I've got the dually D2 diffuse in the exact same place and they're perfect...much better spread and more even than the spots or floods for that matter...
The Macf
Vegas
Yep. Love my diffused in the leaf springs. They work even better with the red covers on them so I can use them as rear fog lights.
J DAMAGE
NJ
I'm gonna pull them out being there new, so they don't get damaged, see what I can get for them money wise, and go from there,
J DAMAGE
NJ
This just to let you guys know, you don't have to get RAPTOR specific switches, any of the F-series switches will work, being its a mod, just make sure you get the correct pigtail that goes with the switch your using.
kboss87
Ordered the RIGID Raptor 20" LED Light bracket for the front bumper and a 20" light bar.
Still patiently waiting for my truck
