Gryphon313
Western, WA
@Gryphon313 how does that wilco rack mount to the rails? Looks like a clamp system or did you have to drill holes?
Clamps. Long bolt goes through a threaded aluminum block that is bolted to the rack via the circlular plate in the second pic. The bolt pushes another aluminum block up against the bottom of the bed rail. Lots of options for placement of the clamps to avoid the plastic bed cap push pin things that pop through the bed.
TomDirt
Hesperia CA
Andddd... stops.
I wrecked the 4" angle grinder discs.20231121_162720.jpg(Trying to use them in a 4-1/2" tool; couldn't find any 4-1/2"s around). The 6" angle grinder & the Sawzall only worked for cuts perpendicular to the bucket, too big to maneuver around everything else. Either way, I'm committed now.
wjoutlaw
San Antonio, Texas
What tubes/specs? DM if you want.
Standard published minimum contract specification requirements. 64lpm, SNR 25, Halo max of 1, EBI 3. Those are the numbers I look at. In reality, most Omni-VIII tubes I've seen perform way better than that. I'd have to send those into Ident Marking to have them tested for actual specs.
