dj30417
CRZYCHK
Your basement
I got to speak with the nicest state trooper today. Happy Independence Day!
Returned to the scene of the crime today only to recall that I had been behind two slow pokes who turned off and I decided to let her roll, less than a mile later there he was driving in the opposite direction. Just my luck. :)
badm0t0rfinger
Rocket Man
The Beach
Yep. If it’s a HDMI model get you a adapter from Amazon and let it rip
Which is awesome because if you wanted hdmi from an old console even just a few years back you had to modify the console itself and those went for 200+ easy. I saw a dream cast that was modded and it was 500+.
dj30417
CRZYCHK
Your basement
I’m 5’ 3 3/4” I don’t need a step stool but my cousin, who is a full foot taller than me, thought I did. He didn’t like the backwards hand press hop I always use to get my 105 pounds in the back of my truck. I have a base model, so no stripper pole. :(
I moved it away and tried not to laugh.
Gumby
Nashville
Well it was emergency brake day at "Gumby's garage" replaced the rear pads on @mwaite09 when doing so found the E brake shoe was dragging on the drivers side for a while. When replacing the shoe found the E brake cable cam was completely rusted/ froze up. It took a few min to get it out cleaned up moving again.
If you use your E brake and when you release it and your light stays instill you pull the pedal up with your toe. You are having the same problem.
After mwaite it was Time to check @Bozz yep same problem.... not quite as bad we were able to free his up a lot easier. Didn't need pads or shoes. Going to tackle the wife's next... Although the pedal returns on it own. It Will not hurt to get sone anti-seize before it becomes a problem.
