Gen1TillDeath
cincinnati
I would check with livernois then, I'm not a tuner, but you can always regap them, I know, major pain to do that. I believe the reason for the smaller gap on forced induced motors is because you can get a misfire with the larger gap, now the reverse might be that you overheat the plug, IDk. You need to talk to a tuner, if you are set on veering away from stock specs.
Thanks man
MurderedOutSVT
Brodozin
The ATL
I believe 30 is for s/c and 44 is what i used for stock, don't believe anything I write on here though.
Here is a blurb from JDM:
DESCRIPTION​
NGK Spark Plugs 6510 For The Ford Raptor 6.2L Trucks
When adding aftermarket upgrades to your 6.2L Ford Raptor truck it is recommended to upgrade your spark plugs. JDM recommends these NGK-6510 LTR7IX-11 Iridium IX spark plugs. JDM uses NGK's in all of their performance vehicles. They are reliable and are made with quality.These NGK-6510 LTR7IX-11 for the Ford Raptor's 6.2L ensures high durability with the fine Iridium tips. The Iridium alloy has extremely high melting point which is perfect for the high-tech performance Ford Raptors.
If just adding a custom tune or a supercharger NGK-6510 is what you need. Gap should be @ .030 ( but do not come pre-gapped)
COMES IN A SET OF 16
Highly recommended when installing aftermarket supercharger kits
@Gen1TillDeath
.30 on DSC-1 with a 93 tune. Motorcraft plugs...all 16 of 'em
Granted...8 MPG....but who bought these for the mpg.
SJC8713
NorCal
In a surprising turn of events the dealership called me at 4:50pm saying the truck is done and they're open until 5:30pm.
So naturally i raced down to grab it. They attempted to charge me $900 for the repair until i mentioned again this was the recall/warranty repair. To which they promptly fixed and i was on my way.
Drives great! I saw they replaced the fluid and the filter. I thought per the work order it was to re-use the fluid and filter? I guess i got a free transmission service.
CoronaRaptor
CANADA
That's great news, but who in there right mind would drop the pan and reuse old fluid and filter, that's something TRX owners would expect though.
mprice1234
SVT Gen 1 Rules
Colorado Springs, CO
So the dealer would have taken your money if you hadn't brought up the fact its recall/warranty repair?
mprice1234
SVT Gen 1 Rules
seems that way. Whats even worse is the work order verbiage states its the leadframe recall/warranty repair. Prior to removing the cost.
Glad you got your truck back fixed without costing you but man that's sad about them trying to charge you! And dealers wonder why customers call them stealer-ships! :mad:
