BlueGoliath96
Installed black rhino wheels armory + hellwig rear swaybar + thicker IWE rings from RPG + replaced factory IWE vacuum hose with new silicon ones .
BlueGoliath96
You running a mid travel or lift kit? Truck looks tall!
Indeed ,
The truck has a BdS 4inch lift and Fox 3.0
Complete kit set at mid perch (equivalent )
Adv fiberglass 2.5 fenders front and rear
Total chaos UCA
17x9.5 black rhino wheels
40x13.5 Milestar tires ( highly recommended tires )
HELLWIG rear swaybar
4.88 Nitro Gears front and back
Raptor retrofit morimoto headlights
S&B cold air intake
Lee power steering reservoir
Mishimoto upgraded trans cooler
Optima Yellow top Battery ( highly recommended )
Rigid D2 Fog lights
Interior Additional 4 Custom AUX switches
SCT TUNED for 40s and the 4.88 gear ratio
PorterW1111
Florida
Indeed ,
Total chaos UCA
S&B cold air intake
Rigid D2 Fog lights
Pshh...lift kit...cheater lol I went through so much to run 39s, you just throwing 40s...smh...lol kidding. Looks sick! How do you like 4.88s I have mine in the box still contemplating install...
Jonny V
Carnation, WA
sure its the pump and not the hose?
The Lee kit replaces all the flexible lines so my bases are covered. For about $150 more than what the dealer wanted I’ll have a fully upgraded power steering setup that solves a known weak spot with the Raptor (Ford pump and small reservoir)...
BlueGoliath96
Yea I also had to do a lot of firewall work and modifications -hammer those pinch welds . As for the re gearing , I don’t regret it at all have done it 2 years ago and truck is smooth with 40s
As you know it accelerates faster from a stop but highway speed is reduced because of the higher gear ratios .
I also did some calculations with Carson at nitro and gears , the 4.88 is the way to go with 40s
“If you are running 40" tires on a Raptor, I'd suggest a 4.88 gear set to correct for the tire size. A 5.13 ratio would be the most aggressive, but would have sacrifices for daily driving and not be as strong as the 4.88 design due to the smaller pinion head”
P.S reason why I recommended the Milestar tires they are a lot cheaper than other 40s + heard a lot of great feedback + it weighs 84lbs compared to let’s say. Nitto 40 which is 110 lbs so that’s all unsprung weight
Still a heavy tire no doubt but the weight difference is a +
