ezndo
FL
How many miles on the old ones? Noticeably better ride?
90K on the old ones. Ride is better, but I also replaced the passenger UCA and had it aligned immediately after the shock replacement so.....
Deleted member 12951
Guest
Passenger side IWE failed losing its vacuum which stayed engaged but the driver side was doing all the grinding since the system couldn’t hold enough vacuum on the opposite side. Dealership under warranty replaced the passenger side. I asked them to check the gears on the driver side since it was the one grinding and figured they must be torn up. They said replacing the passenger side fixed the issue and they didn’t need to do that.
BTW, these are the original IWE’s at 90k miles, first time failing. Decided to replace the driver side myself.
Amazing to me that they lasted this long and the driver side was fine so really didn’t need to be replaced but did it anyways.
Also replaced the brakes with the Freedom Motorsports package, the Rotors, Pads, new calipers that I painted, flushed the brake fluid and I did the lines in Stainless awhile back.
