badm0t0rfinger
Rocket Man
The Beach
I've been changing out the power steering fluid over the past few days. Basically every day before work I'll grab my handy turkey baster and remove some fluid before replacing it with new mercon LV. I've noticed that it went from smelling burnt to sweet. Its not terribly efficient but it works.
siooss
Florida
Replaced the starter. Bit of a challenge, but after took off the fender flare/liner, it helped greatly to see and get at the top and middle bolts, definitely recommend removing, especially if have headers. Bought Reman from FordPartsGiant.com $82.
Picture below is new starter next to old starter, figured after 8 years, time to replace, started to get that pause/delay, then start thingy happening. Previously replaced the starter and ignition relays.
Old starter before removal in picture below, soaked the bolts, both ends, with Kano Penetrating Oil using bottle with needle applicator, worked like a champ, they broke free pretty easily. The silver tape is heat reflective tape on solenoid since right next to header pipe.
Picture below of new starter installed with heat reflective tape on solenoid, cleaned up the battery cable ends and coated in dielectric grease to reduce corrosion. I used very small / short 1/4 drive ratchet with 13mm socket to get at top bolt, and very small / short 1/4 drive flex head ratchet with 1" extension and 13mm socket for middle bolt, the bottom bolt is 15mm.
Deleted member 12951
Guest
Pulled the dash apart to replace the temperature blend door actuator. Passenger side was on full heat, the wife was not a fan...........
All I wish for is for both of them to go out while mine is still under the ESP warranty.
Buzzard2
Sincity
Picture below of new starter installed with heat reflective tape on solenoid, cleaned up the battery cable ends and coated in dielectric grease to reduce corrosion. I used very small / short 1/4 drive ratchet with 13mm socket to get at top bolt, and very small / short 1/4 drive flex head ratchet with 2" extension and 13mm socket for middle bolt, the bottom bolt is 15mm.
I am getting that pause before the starter cranks periodically, So it is probably the starter and not the ignition relays?
Buzzard2
Sincity
Does the cost include shipping the core back or is that up to you? Might be cheaper to eat the $25.00 core charge vs shipping it back.
MTF
Celebration, Florida
The headers really cooked that starter,
I hope you can find some Stainless steel, aluminum or galvanized sheet metal and add that with a hose clamp that will completely cover the whole starter to the heat wrap.
I would wrap the headers right where the starter is also.
Jakenbake
Believe it or not, this dash was the easiest I have taken apart. Having said that I only replaced the temperature control one behind the radio. I think there are 4 total and that two might be able to be changed without removing the dash at all. Someone correct me if I am wrong. The upper drivers side one is supposedly the worst as the whole dash has to come out.
