Buzzard2
Sincity
Loaded the JDM engineering Tune. Took her for a brief drive so far very happy with their tune. Shift points feel great, downshifts very smooth and much better throttle response.
siooss
Florida
Did another "me too" upgrade, swapped out to the heavy duty transmission cooler, easy enough. Recommend not adding transmission fluid to the cooler as recommended. I added the recommended amount by Forge Off Road and resulted in overfull condition with transmission fluid that came pouring out when removed the plug/dipstick. Had to remove some fluid, oh well. Easy enough to add fluid through the plug/dipstick if needed.
siooss
Florida
Was the fluid level checked with the engine running or not running? It needs to be running. Not running and it will always overflow.
running at normal idle, fluid at normal operating temperature, gauge showed 192 when did the check, vehicle in park, wheels chocked, wore thick leather gloves, as the header collector is right next to the plug, haha, it does get hot under there.
Deleted member 12951
Guest
I added a 1/3 quart, no issues
But what is that CAI you have? At first I thought the thing was duct tape.
