WH7
installed my Power magic pro for my 2 ch dash cam. Screwed up my truck with forscan, not sure what I fat fingered but when I hit the blinker it would blink 10 times really fast. restored to original from back up, corrected my mistake.
Have to wait until tomorrow to test everything,( DRL), but most of it seems to be fine now. (knock on wood)
Bulletnjm
New Jersey
Nick, you ever going to install that SVC bumpstop? You need to use that last hanger holder for the exhaust.
I think I’m going to put it on this summer. I had no reason to have it on during the winter so i kept it off to keep the salt off it and keep it in ok shape. I want to pull the bed and clean up some of the rust it looks bad under there
Deleted member 12951
Guest
Let's see, after the rain let up yesterday. I checked tie rods, tire rotation with putting the 37's back on, fix front brake lines, installed transmission skid plate, removed spare tire underneath and removed the spare tire crank, cleaned up wires in the rear with a bunch of zipties, changed out rear flares, installed fire extinguisher in bed cage, flushed power steering in reservoir, ran Baja Design 40' racer in bumper for an hour after removing lenses to dry out the moisture and installed new lenses and seals, found a failed relay for it and replaced, fixed transmission hoses in the front, found front carpet is wet again and towels soaking it all up (wish I could find where the water is coming in), removed rear mudflaps. Got more to do today. It's never done but has to be by Tuesday.
Ass went up with removing the spare, should have the rear loaded today to get it back down
