FordPerf Addict
Pressure washer to the running boards and trim. Black plastic trim I usually one of those deep black trim soaps and scrub it on and wipe it off when it is really stained or just wipe on and off if discolored.
Sent from my Pixel XL using Tapatalk
Other people might say different but using dish soap on the running boards does clean them, but hurts more than it helps.
---------- Post added at 09:10 PM ---------- Previous post was at 09:08 PM ----------
That looks awesome! I ever find a use for more than 4 I know what I'll be doing now!
Use VRT from Adams polishes on the black plastic it really brings it to life again and darkens it
JtoU
Installed bed side support and test fitted tool box's with new parts. Still need re route that rear camera wire harness. I did cut the bypass lower shocks mounts off and moved those little bit more inward. I had slight rubbing to compression tube at full articulation.
highpowernut
I like your trailer! Is that a custom job?
Yes custom trailer has independent suspension, front hitch extends, working to find adaptors for wheels to have same pattern as truck, that way wheels are redundant.
It goes anywhere the truck can, has no problem at speed either.
This is the first edition, I am planning on upgrades and mods . Might just build another if it becomes too much.
gryGhst17
That's sweet!
CFIT
Valencia, CA
I dig that trailer. Did you build it from scratch, or was it a kit of some sort?
