Deleted member 12951
Guest
At 65500 miles of today had the coolant flush done, road force rebalanced tires. Ordered rear stop tech cryo treated rotors and and Akebono street pads. Also somehow managed to wonder off to Rappygrahics site when I got back in the office and ended up scoring July 4th special full hood wrap $274 for $114 shipped.
Got the same hood graphic but added the valance piece. My OEM hood wrap got some holes in it from branches so thought it was time to replace it.
hkguns
Installed the @Baja Designs Onyx 6 light bar and covered the front skid plate with bed liner.
In my opinion the skid plate looks much better all black. Gives the truck a more aggressive look and blends in with the front bumper.
The258
McAllen TX
New cargo lights arrived today. Put em on and siliconed the brake line, hopefully that'll stop the water from leaking in.
Bar
SoCal
Kicker sub box and kicker door speakers installed today. Sounds incredible, but still making adjustments to the bass levels. Much, much better than stock. Tapped into the sub speaker wires instead of the front passenger speaker wires.
The258
McAllen TX
Pretty bright cargo lights. Just need to remove that light bar and put pods instead.
NorhternILRaptor
Northern IL
Replaced the rotors and pads today at all four corners.
Taking off the right rear rotor was a bear. I must have tightened the parking brake instead of loosening it. Ended up pulling the spring hold down pin through the backing plate pounding the rotor off. Sometimes the brute strength method gets me in trouble.
Anyone have any advice on replacing the backing plate? I am going to call around tomorrow to see if any of the local parts stores have the parts in stock, assuming they won't and I will need to go to Ford to get them.
ogdobber
Installed led bed lighting. Really happy how it turned out. No holes drilled and tucked up so they are undetectable. Used a t connector so i didnt have to splice any wires. The on off switch can be pushed tailgate up or down
