Houston Raptor
- Joined
- Dec 6, 2014
- Posts
- 297
- Reaction score
- 287
Looks great man!
Any tips for cutting into the head liner? I want to install a custom switch panel up there.
Super easy. I was actually a bit nervous cause I have zero experience with anything like this. What I did was measure the entire length of the whole left by the sunglasses compartment, which was 7&1/8. Subtracted the size on the back of radio panel, 5". Left me 2&1/8 of an inch. So went in 1&1/16 on each side and marked a small dot on the bottom of headliner, this part would be covered by the sunglasses part.
The I taped up on each side making sure I had 5" between each end of tape. Then I left the 1.5" of space of height of the back of radio. I used an exacto knife instead of a dremel or oscillating saw that I had heard everyone else using. I thought I would only cut the outside of the headliner and then use a dremel to get through the rest of the material but the exacto knife was perfect.
No jumping of the blade so it was smooth cuts.
Hope I explained everything ok enough.
