WRCRaptor
Great Lakes
Finnished up mechanical mods for Phenonix open yesterday. PSS res and cooler and #27 fuel pump fuse relocate kit.
Before that new front and rear stock shocks, deavers +3 and icon bump kit. What a difference in terms of ride from the worn shocks and the Deavers are very nice.
Truckzor
That's a lot of guages :jawdrop:
Ha! Yeah, probably overkill but I'm paranoid about blowing up the stock motor until there is a better option for replacement.
In order from top left I went with fuel pressure, air/fuel ratio, oil pressure, oil temperature, boost/vac, and water temp.
t_j
Chicago, IL
Order some stuff for some small maintenance:
* Shock seals - all 6 icons, and 8 stock shocks (probably 2 fully rebuild sets going in for for sale section soon)
* 5 Gallons of shock oil
* Schmidty racing N2 Fill/bleed kit and needle adapter
* Replacement ballast and igniter for my drivers headlight
* New uniballs for upper and lower control arms
* AGM Uniball tool hopefully i don't have to take the control arms off the truck this year
Now I'm off to fix some fugly wiring in the truck and fix my rear ambers and halos.
HAP
NE NC
Finally got to install my catch can :)
PropDr, where did you get the ECU connector cover I see in your pic? I have been using a piece of Gorilla tape to cover my connectors. Would like to have what you got there...
R,
HAP
t_j
Chicago, IL
Didn't want to shell out the 135 bucks for the agm Shock shaft vice guards so machine some out of a couple of bucks worth of aluminum.
