What did I break?
Mahoney
Of course, I broke something while trying to do something fairly easy. Everything is plastic these days. I was removing the Turbo Silencer Rings and I apparently was leaning my arm on what looks like the drivers side PCV tube plastic connection and broke it right off the base on this plastic tubing (currently trying to epoxy back on if possible which is why it looks like it's on ok). I tried to look it up and I'm not sure if I can just replace the PCV connection into the tubing ( has a look like the whole thing may twist and remove but I tried that very briefly with no luck) OR I have to replace this whole tube which will be some work and it's over 100 Degree heat index right now on top of that.
35278071344_e405d88f54_z.jpgpcv
36120020945_c353d69057_z.jpgIMG_3641
